1982 carver 3007 aft prop shaftt diameter
thunderbay2tracker
Vessel Info: 1982 carver 3007 aft
Post by thunderbay2tracker »
good evening I'm looking to see if someone can tell me the prop shaft diameter on my 1982 carver 3007 aft. I'm currently away from my boat its a hour south of my location. I was hoping someone would be able to chime in and give me that information thank you I need yo order new zincs for the shafts :captain:
Re: 1982 carver 3007 aft prop shaftt diameter
To clarify, the term is anodes. If you're in MI, you don't want zinc anodes as that is for salt water applications. For fresh water inboard applications, I use aluminum anodes now.
thunderbay2tracker
ok thank you
