OVERHEAD LED COCKPIT / BRIDGE ROUND LIGHT REPLACEMENT
- DAA76
- Vessel Info: 2016 CARVER C40
I HAVE A 2016 CARVER C40 AND WOULD LIKE TO REPLACE MY OVERHEAD LED COCKPIT LIGHTS. CAN ANYONE TELL ME THE BRAND CARVER USED ? I REMOVED ONE OF THE LIGHTS BUT I COULD NOT FIND A BRAND NAME OR SERIAL#. THANK YOU DAVID
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: OVERHEAD LED COCKPIT / BRIDGE ROUND LIGHT REPLACEMENT
Quick question...why are you replacing? Only 5-6 years old, so they should still be in good shape. Are you replacing with the same?
- DAA76
I am looking to change to Blue lighting if possible. 2 of 4 cockpit courtesy lights started to dim so I replaced them with blue lighting.
- buster53
Are you replacing the fixture or just the bulb?DAA76 wrote:I am looking to change to Blue lighting if possible. 2 of 4 cockpit courtesy lights started to dim so I replaced them with blue lighting.
Blue light looks cool but brings in bugs from miles away it seems. I installed blue lights for one season, and then went back to white.
At least with the white you can see what you are doing.
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
You may want to consider checking your area regulations. Blue lights in some areas are restricted to law enforcement vessels only. Sitting at the dock should not be an issue, but lights on while running could draw some unwanted attention.
er
Cooler By The Lake
