Trojan / Carver 440 Express main cabin sliding door
Boo's Cruiser
Vessel Info: 1996 Trojan (Carver) 440 Express
Has thanked: 2 times
Post by Boo's Cruiser »
Greetings -
Just purchased a 1996 Express 440 and have found the glides on the main cabin door are worn out. The glass door seems fine though. Does anyone have any ideas for a source for parts? Thank you! Given the age of the boat, I expect I might be posting here with lots of questions.
Best,
TS - Boo's Cruiser
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Re: Trojan / Carver 440 Express main cabin sliding door
Post by Phrancus »
Same problem with the sliding doors here (1992 26) metal to metal at the moment, literally a sliding door. Haven't taken the time yet to take it apart....
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 414 times
Post by Cooler »
If possible, remove the worn out part and bring that to a local marine store. They are available, a friend of mine just replaced his one on a 94 Sea Ray 420. I believe it is a Perko part, and can be aquired through Land & Sea. 8-) er
Cooler By The Lake
FoxyFlamingo
Vessel Info: 2001 Carver 396 Aft Cabin Motor Yacht
370 HP Cummins Diesels (2)
Post by FoxyFlamingo »
I just took ownership of a 2001 Carver 396. I also have an issue with the sliding pocket door between the salon and the guest stateroom. The door is not hanging level. When closed, the top of the door touches the wall end of the upper track, but the bottom of the door is about 1.5” away from the wall. It looks like it just needs to be adjusted, but I can’t figure out how to get at the adjusters. Can anyone help me get this door to hang right? Thanks
Brian Smith
MV Foxy Flamingo
2001 Carver 396 ACMY
Fredericton, New Brunswick
foxyflamingobrian@gmail.com
Pura Vida
Vessel Info: 93 Carver Mariner 330. 2X 350XL Crusaders
Has thanked: 17 times
Been thanked: 10 times
Post by Pura Vida »
I recently fixed our door. The rollers needed adjustment...very simple, there are screw adjustments on the bottom end of each side of each door. Hopefully pic comes through.
My track was worn and damaged, I installed this track repair - without even removing the door. Loosened the door with the adjustment rollers, slid this track topper in and seated it. Almost like new.
A few tricks to the install, but an average diy job. If you try this, make sure the factory ends are butted together.
