V drive light on
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: V drive light on
Firstclass, I would check to see if you have loose connection. It shouldn’t blink. It should be either on or off above 1200 rpm. Could also be a bad pressure switch.
Ron
“Escape Plan”
Murray, KY
“Escape Plan”
Murray, KY
- Firstclass
- Has thanked: 4 times
Hey there,
I'm currently changing my v drive oil. But I'm a bit wondering about the oil amount I have to fill in.
My boat comes with a manual for Walter V Drives. Still I cannot identify if it's a RV10D or RV20D... any clue?
- KandJ72
- Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process - Location: Central NY
- Has thanked: 20 times
- Been thanked: 3 times
Firstclass,
Is the light a constant blinking/flashing or somewhat random? If it's random it could be a bad contact on the bulb itself, I found that issue with my '76. At idle while docking Port side would stay steady and Starboard would flicker and flash and then at times not come on at all. I tried swapping pressure switches, no change, tested with manual pressure gauge, all good, finally found the one bulb socket was just loose!!!
- KandJ72
Twin 351W Vdrives
Firstclass,
Here is a link to the service manual for Walter V drives. I was only able to skim it quick yet it might help in identifying which unit you have. I did see the fluid difference is 1 pint or 2 pints, If you cant figure out which it is I'd say add just 1 pint 1st and check level. Then add only if it seems very low at that point. Hope this helps.
http://www.svsarah.com/Sarah/Manuals/Me ... -Drive.pdf
- Torsson
- Vessel Info: Carver 28 Voyager 1988 Twin 350 Crusaders
Firstclass wrote:Qr Bbpost Hey there,
Is there a difference between the v-drive light staying on or blinking? Mine is blinking continuously while driving above 1200 rpm
It should not do that. If you wan't help start a own thread about it and you will get help
Did miss the second page and ppl are helping you. sorry
