30 amp or 50 amp cords - dumb question
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 23 times
Someone needs to explain to me whether I should buy another 30 amp cord (or just the female plug) or use the 50 amp cords and in what configuration.
Thanks.
- Has thanked: 72 times
- Been thanked: 1054 times
Re: 30 amp or 50 amp cords - dumb question
You can either replace the entire cord or just the female plug. Just make sure you make good correct connections if you replace the plug and get a good waterproof boot to put over the connector.
More importantly though, is you need to check the sockets on the boat. The connections on the back side of those sockets could get corroded or loose, resulting a high-resistant connection that WILL heat up under load, which can also damage the female connector plugged into it. I had a friend with a 356 who had that issue, He was surprised at how bad the connection on the back side was and had to cut a few inches of the cable off to get to good cable to reconnect. His socket was OK but if he had left it too long that could have been damaged too.
- Has thanked: 270 times
- Been thanked: 1159 times
IF, 50a is not available at another marina, you will need to use the splitter you already have which will plug into 2 30a outlets on the pedestal then into your 50a cord and use the same splitter I just told you to purchase.
OR, you can simply continue to use dual 30a cords with no splitters however I do recommend you change them both to new all around as if one is on the blink the other is not far behind. They do become serious fire hazards with time.
