1985 Carver Voyager 28 Deck escape hatch replacement
- Merkinbrumsky
- Vessel Info: 1985 Carver Voyager
- Has thanked: 53 times
- Been thanked: 38 times
Wondering if anyone knows of an exact replacement for this hatch. It leaks badly and dogs are broken off. It appears to be plastic. Hole opening is approx 19 7/16” x 19 7/16. It has 2 cross bars under the lexan. 1 running fore and aft and the other running port and stbd. Thanks
- Been thanked: 1114 times
Re: 1985 Carver Voyager 28 Deck escape hatch replacement
That's the same model used on many Carvers going back to 1982-1983. It was made by Grey (or was it Gray?) Industries who are now part of Pompanette.
I doubt you'll find the same one anywhere, even at a 'boat junkyard', at least one on good enough shape to replace yours. Ever now and then though, you'll run across someone parting out an old boat on Craigslist.
- Merkinbrumsky
Thanks for the fast reply. I guess I will have to find a non original replacement then. Damn.
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Mine (1992) was replaced somewhere in its history, I'll check the brand name. I noticed it yesterday but can't pull it out of my memory now.
Size seems quite normal so replacement should be ok to do. I see you have some mosquito screen in it? Mine had a separate screen to clip on, of course some previous owner lost it.
- Phrancus
- Contact:
Perhaps this helps you source a replacement:
Bomar sounds familiar but a quick we search brings me 'osculati' too, nothing obscure: big company
I don't know why I get to this page when searching bomar and that number but it looks exactly like this one:
Yachtshop.eu
I did not measure mine and perhaps this is a serial number, not a product number.
From the looks of it, you just need to figure out the size (seems reasonably standardized, looks like yours is the 19" version?) and source a set.
Yachtshop.eu
- Merkinbrumsky
I ended up ordering a Bomar 900 series. Looks like it may be the same one you posted. May need to enlarge the cutout slightly but should work out good. Got it from defender at a good price. We’ll see when it gets here how install goes.
