NEED PROPS
Forum rules
All classified ads for boat parts are free. Please be as specific as possible in describing your item. You can upload pictures too!
CarverYachtOwners.com and the owners of this forum take no responsibility for the authenticity of ads or legitimacy of items being sold. Buyers, please buy responsibly.
To place an ad start a new Topic. We reserve the right to delete ads from users with fewer than 10 posts.
- jimpeter
- Vessel Info: 2005 41 CMY
NEED PROPS
42 MARINER 2004. VOLVO GAS ENGINES LOOKING TO PURCHASE 2 PROPS. ANYONE KNOW WHERE I CAN??
- C0ps
- Vessel Info: 1992 carver montego 528
- Has thanked: 3 times
- Been thanked: 6 times
- Been thanked: 492 times
Re: NEED PROPS
So far, 4 boats, and for each I bought spares on ebay.
Way cheaper than new from a marina, and all but the 3 cleavers, were all brand new.
I didn't need the props, I just wanted spares, so I had time. If you need them right now, you may need to shop supply houses for the best deal though.
I bought brand new spare Michigan wheels for the 3697, 600 bucks for the pair. You can get a good deal if you have the time.
- jimpeter
Re: NEED PROPS
ANYONE KNOW HOW I CAN FIND OUT THE EXACT INFORMATION ON THE TYPE OF PROP I HAVE? MANUAL STATES... HAWBOLDT INDUSTRIES PROP 24X24 DQBZ MG4 1-3/4
- jimpeter
PROPS
HOW CAN i READ THE DESCRIPTION ON MY PROPS. MAUAL STATES. TRYING TO BUY NES SET BUT VENDORS ARE ASKING FOR PITCH, CUPPING, ETC. CAN ANYONE HELP OUT....CARVER 42 MARINER.. HAWBOLDT INDUSTRIES PROP 24X24 DQBZ MG4 1-3/4
- Been thanked: 1114 times
Re: NEED PROPS
That would be a 24" diameter 24" pitch with a 1-3/4 shaft. I would not expect it to be cupped out of the factory, but you never know what a previous owner might have done. You can usually double-check the shaft size by measuring where it comes into the boat.
If you don't have any spares (and I'm a FIRM believer that you should), then you if you could find a set CLOSE to those 24x24 specs for a good price, then I would pick them up and use them and eventually convert them to your spares when you find the permanent set. As long as the shaft size is the same, they will work but may not be optimal. Say, you might find a set of 24x22 or 23x23 or even a set of three blades vs the four that you presently have. It will get you back on the water. You can continue to search for an exact match for your permanent set, or you might run on those spares and find that you'd like to change from the OEM prop to something else for better performance on how YOU use the boat.
Re: PROPS
24 x 24 is diameter x pitch
1 3/4" is shaft size
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: PROPS
What’s wrong with the old ones? Unless they are mangled, there’s a decent chance a good prop shop can fix them. Took mine in for service as one had a blade a little out of pitch. Looked brand new when I picked them up and had a prop scan report to go with them.
- buster53
Re: NEED PROPS
Have you tried Google? Lots of prop shops out there and for something like you are looking for, I prefer buying local. You might want to let us know where you are located as we might know of a good shop near you.
