Steve
Those two definitely needed to be repeated and highlighted!!!Viper wrote:QR_BBPOST ....
This highlights the need to work your seacocks periodically and lubricate if conditions are bad enough, especially in salt water applications.
Don't pinch the intake hose, pinching the hose will distort it as it's typically a wire wound hose. Even if you try to squeeze it back into shape, you've permanently bent the wire and while it may not be noticeable on the outside, you may cause the wire to break through the inner surface of the hose which can lead to a shortened lifespan and other problems. Simple wood plugs will help, even shoving a rag in the hose until you're ready works good.
Can just as easily be fresh water as well, depending on maintenance and whether the boat in question has ever had electrical corrosion issues, whether from the boat/dock or slip neighbors. So keep operating them on a regular basis and keep an eye out for corrosion.....once a year is not enough IMO.Midnightsun wrote:QR_BBPOST I think this is more of a saltwater issue though as I know of nobody who has had this issue in all my years of boating in fresh water.
Yup, that was a while ago, they were nice for us guys that could take that valve apart, clean and lube it......the T handle was actually repairable as well.Viper wrote:QR_BBPOST Bud, if you're talking about the ones I'm thinking of, yes they were Groco. The problem still applied back then though. They had a locking T-handle that you tightened so the valve wouldn't accidently change position. The problem again was that people didn't exercise them enough, so the T-handle would corrode in place and when you tried to loosen it you'd break the T, making it impossible to move the valve handle. Once that happened, it was toast and no rebuild kit would remedy the issue. Can't tell how many of those I've ran into over the years. They were a very popular design back in the day and there's still a lot of boats out there with them but no more rebuild kits from the OEM.
