Strike plate for a 396
frankptam
Vessel Info: 2000 Carver 396
Post by frankptam »
Hello, We lost the strike plate for an aft cockpit door. Does anyone know where I can find one? Thanks, Frank
frankptam
Re: Strike plate for a 396
Post by frankptam »
To be specific it is the strike plate for the glass door, thank you
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 149 times
Post by KyleR »
Are you talking about the "wing" doors that lead from the aft cockpit forward along the side of the boat? Do you have a pic of the part you are referring to? I'm having trouble picturing it.
MV Verity
2002 Carver 396
frankptam
Post by frankptam »
Yes those are the doors that I'm referring to.
KyleR
2002 Carver 396
Post by KyleR »
Is that on the door itself or on the door frame? We have a 2002 396 and have a much different latch setup. On ours the door frame has a "male" strike plate that engages with a "female" latch on the door. Here are some pics from our survey day of our setup. Yes I realize the frame looks just awful :-( - but at least you can see the kind of latch/strike plate we have.
MV Verity
2002 Carver 396
frankptam
Post by frankptam »
Kyle ours has the female on the door.
KyleR
2002 Carver 396
Post by KyleR »
Gotcha - I don't know about an exact replacement, but if you take the one you have to hardware stores (big box and/or local) you may be able to find a stainless steel strike plate that has matching holes. Then just replace them both so they match! :-) But I am guessing you probably already considered that. Good luck! I still am surprised by the difference in the latch mechanisms between our boats. But with all the weird stuff I have found on ours I wouldn't be surprised if our doors had been replaced at some point! :lol:
MV Verity
2002 Carver 396
