We hauled out for the first time this week. Woohoo!
Was wondering what these circular ports were on the transom. There are two next to the throughhull for the depth finder wiring and two in between the two drives.
[img]20221109_145044%20(1).jpg[/img]
What are these ports on the transom?
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
Fun times on the 1988 Carver Santego 30
- Been thanked: 1312 times
Re: What are these ports on the transom?
Can't really see but if they have thin rubber flappers they are probably scuppers for the deck drains......have a look below between the engines at the aft of the engine room.
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Yeah, the two above the water line are drains for the self bailing system in the cockpit. The bottom two may be either underwater light installations or caps from previous underwater lights.
er
Cooler By The Lake
The two bottom ones look like the older versions of Mercruiser's electronic active anti-corrosion system (Mercathode).
