Cutlass bearing replacement determination - 1984 Mariner 3697
rictamily
Vessel Info: 1984 mariner 3697
Has thanked: 14 times
Been thanked: 2 times
Post by rictamily »
Hi,
My prop shaft is 1 ⅜ diameter. I have the boat on blocks so wanting to do maintenance while on the hard. The props are removed and when shaking prop shafts there is movement...movement enough to make a slight clunking sound when emphasized. Is there a certain tolerance?
Also, is the process of replacement just a cutlass bearing-removing tool to remove and replace? Or are other calibration methods required?
Re: Cutlass bearing replacement determination - 1984 Mariner 3697
Here is a quick reference i came across.......can't specifically answer your clearance question as I don't know....
https://www.pacificmarine.net/engineeri ... arance.htm
rictamily
Post by rictamily »
Thank you so much for your time.
