Cummins 5.9 330 hp
Fishsail
Vessel Info: 1991, 420 aft cabin
Has thanked: 17 times
Cummins 5.9 330 hp
Post by Fishsail »
Anyone running these in a 42ish size boat? Curious about fuel burn? At slow speeds, say 7-8 knots
Tnx
Fishsail
Re: Cummins 5.9 330 hp
Post by Fishsail »
:captain:
Are you experiencing more fuel usage than expected or less ?
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 149 times
Post by KyleR »
I have twin 5.9 6BTA 370HP - not exactly the same but very similar. And we run almost exclusively at 7-8 knots (1050 - 1150 rpm), except to run the engines up near the end of each run to prevent carbon buildup.
I've been tracking it for about 5 months now and I'm averaging 3.5 gal per hour for both engines combined (i.e. 1.75gal/hrs per engine).
Also works out to about 2miles/gal overall.
Hope that helps!
MV Verity
2002 Carver 396
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 414 times
Post by Cooler »
Wow! I am impressed. That seems pretty efficient. I think I will try some speeds like that with my gas engines. Just to see what my fuel burn would be. 8-) er
Cooler By The Lake
There is always a sweet spot somewhere between GPH and NMPG, especially concerning time/distance covered.
Fishsail
Post by Fishsail »
KyleR, yes that sounds pretty good. We’re moving over from a 6 knot sailboat so 7-8 knots is perfectly fine for us. I was hoping to get 500-600 miles on a full tank full. Tnx
Fishsail wrote:QR_BBPOST KyleR, yes that sounds pretty good. We’re moving over from a 6 knot sailboat so 7-8 knots is perfectly fine for us. I was hoping to get 500-600 miles on a full tank full. Tnx
Don't forget to consider the third rule....1/3 out.....1/3 back...1/3 left over. That will cover issues, weather, currents etc. You really don't want to run boat tanks real low.
Y2K996
Vessel Info: 1996 Carver 500 Cockpit Motoryacht 420HP 8.3L Cummins. 3 bedroom 2 bathroom layout. Enclosed flybridge and aft deck with 5 air conditioners. Available for charter in the Sarasota to St. Petersburg area.
Been thanked: 3 times
Post by Y2K996 »
I have 6BT 215hp Cummins in my 42'LOA 390 CPMY and I consistantly get 2.3MPG at hull speed and 1MPG at cruising speed. I have wonky fuel gauges so I always fill up the saddle tanks and check my mileage and have never gotten less than 2.2MPG. Of course, my horsepower without an aftercooler is nowhere near what you have but it works for what I do with it.
MV TATANKA
Vessel Info: MV TATANKA
2000 Carver 406 Motor Yacht
Cummins Diamond 5.9 370HP
Has thanked: 8 times
Been thanked: 2 times
Post by MV TATANKA »
KyleR wrote:QR_BBPOST I have twin 5.9 6BTA 370HP - not exactly the same but very similar. And we run almost exclusively at 7-8 knots (1050 - 1150 rpm), except to run the engines up near the end of each run to prevent carbon buildup.
Hope that helps!
This is excellent information, I just bought a 406 with the 370HP Cummins option and am trying to find burn data.
