lock cylinders needed
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
anyone have a source for new lock cylinders or even new latches for the sets of sliding doors on a 1994 39 Cockpit Motor Yacht? I would like to replace new rather than remove the cylinders and bring to a lock smith.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: lock cylinders needed
Great Lakes skipper.com should have something.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Contact Carver with your hull number and they should be able to give you a part number and manufacturer, they may even have them in stock. It may be a Southco lock. You can also contact them, send a picture and see if they can match it up. Here is their site with contact info:
http://www.southco.com/en/mg
- Howard
- Vessel Info: 2000 carver mariner 350
Nauti Tymes - Location: Maryland
try If memory right southcoin at 6104594000 told me they had complete lock assemblys
- tonyiiiafl
GOT lucky! I was rummaging through a draw and found the keys to the sliding doors! Now to have a few copies made! YEAH is me!
If you can't find anyone with blanks, try http://mobellakeys.com/products/Mobella_Blanks.htm You can get blanks from them or order the cut key by giving them the number stamped on your key. Keep in mind there are 800 and 900 series designs. The first digit in the key number indicates the series.
