Hello, I have a 2008 Mariner second owner. Prior owner had damaged the bow thruster engine with water. It has now stopped working and pulled the bow thruster motor from the boat. Volvo Penta Factory Bow thruster and it seems there is not being produced any longer? Question. Where to find a replacement Bow Thruster Motor or repair to rebuild.
Mike
36 Mariner 2008 Bow Thruster Needs replaced or repaired
- Been thanked: 1312 times
Re: 36 Mariner 2008 Bow Thruster Needs replaced or repaired
Maybe try some local automotive electric motor repair shops........ like starters/alternators etc....
Be sure to point out it is marine.
- MBoone
- Vessel Info: 2008 CarverMariner
- Has thanked: 6 times
Thanks. I did that with great success. Like New Motor rebuild $750 and works great. Mike
Post the info where you had it done so others in your area know where they can do the same.
