96 mariner 330 throttle cable
- CaptainChuck
- Vessel Info: 1994 Carver Mariner 330
Re: 96 mariner 330 throttle cable
Welcome aboard.
You'll need to know what length you need but Teleflex Supreme cables are really good. Any marine parts retailer will be able to get them for you. Look for a number stamped on the cable at either end, the last few numbers represent the length.
What leads you to believe the cable needs replacing? If things are stiff it's a pretty good bet but it's not the only thing that can cause that symptom.
- CaptainChuck
Thanks viper, boat set in the water 3 and a half years before I got it and one cable is sticking, I want to do everything I can while she's in dry dock
