How to work the head on my boat
eriklee200
Vessel Info: 1990 Carver Montego 3257
Post by eriklee200 »
Hi All,
I have a 1990 Carver Montego 3257 and curious if anyone can walk me through the operation of the toilet that I have (pics attached). There is a dry and flush dial as well as an electric flush push button. The seacock is open but it feels pretty firm when I try to slowly pull the handle up and seeing there is a lot of plastic here I don't want to force anything and have breakage. If anyone can share a basic process I would be very grateful. My last boat was more of just a porta-potty.
Thanks,
Erik
Re: How to work the head on my boat
That is a Raritan PHEII toilet. It has the ability to run it electrically or manually via the handle. Don't try to use the handle though if the motor is actually hooked up to the pump. If the motor works, remove the handle and keep it aside. If the motor fails, unhook the motor linkage, install the handle and you'll still be able to use the toilet albeit as a manual flush. If you push the button and the motor doesn't run, that's a separate electrical issue that requires some diagnostics. It's either a bad switch, bad motor, bad wiring, or bad breaker. With the motor running and mechanically hooked up to the pump, it will operate the pump just as you would via the manual way using the handle.
"Flush" brings water into the bowl as you operate the pump, "Dry" evacuates the bowl's contents as you operate the pump.
These are good toilets by the way, very well built, robust, and totally rebuildable.
eriklee200
Thank you so much for the reply. I really appreciate your guidance and believe the motor is all set to go so I will put the handle away for safe keeping.
Regards,
Erik
Been thanked: 1114 times
Everything Viper said... and if the flush/dry valve is stiff or hard to move you can remove it and lubricate it with any teflon grease and reinsert and it will work much easier.
Grafunkus
Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin
Has thanked: 63 times
Been thanked: 32 times
Post by Grafunkus »
Viper wrote:QR_BBPOST "Flush" brings water into the bowl as you operate the pump, "Dry" evacuates the bowl's contents as you operate the pump.
We have one, but without the electric option, does this actually mean you turn it to flush first, pushing the handle down. Then turning it to dry as you lift the handle?
Grafunkus wrote:QR_BBPOST
Not really. If you want to fill the bowl with some water before you use it, then turn the handle to flush, and pump a few times. Then turn it to dry and pump till the bowl is empty. Or if you just want to rinse the bow turn it to flush, pump a few times, then turn to dry and pump a few more times.
daveincave67
Vessel Info: 1984 3207 aft cabin
Post by daveincave67 »
Where do these get water from? Seacock? If I take the top assembly off at the toilet will I sink?
Typically there is a seacock. If the toilet is above the waterline you won't have an issue. Not sure what part you're talking about as the "top assembly", but you can take the water hose off at the bottom of the pump and plug it if you can't locate the seacock. On your boat the seacock probably feeds both heads and the line probably goes to a "T" fitting right after the seacock and splits to feed the fwd and aft heads.
