Bilge Blowers
TruckerTim
Vessel Info: 2000 Voyager 450
Sarasota, FL
Bilge Blowers
Postby TruckerTim » August 6th, 2023, 2:24 pm
I have a 2000 450 Voyager and none of the blowers are working. Engines on or off, no air flow. Breakers in the salon panel all show on bilge blowers # thru 4 on and not tripped. I crawled behind the starboard fuel tank and I can see the ducts running the the engine bulkhead, but don't see anything that looks like a fan or blower motor. I do see a white, round connection, slightly larger than the duct... Is that the motor?? Thanks
Has thanked: 268 times
Been thanked: 1153 times
Re: Bilge Blowers
Postby Midnightsun » August 6th, 2023, 3:04 pm
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 115 times
Been thanked: 114 times
Re: Bilge Blowers
Postby KyleR » August 6th, 2023, 3:18 pm
Not sure if yours is the same as mine but the relays for fans 2, 3 & 4 are "slaved" off fan #1. In other words, if fan 1 does not have power none of the others will run either. I don't know if this has any bearing on your situation but it took me some digging to figure this out when I was having fan issues. Good luck and keep us posted on what you figure out.
MV Verity
2002 Carver 396
Has thanked: 579 times
Been thanked: 1210 times
Re: Bilge Blowers
Postby bud37 » August 6th, 2023, 3:54 pm
Check out the sticky at the top of the electrical section.....
TruckerTim
Sarasota, FL
Re: Bilge Blowers
Postby TruckerTim » August 7th, 2023, 6:48 pm
Good info there and thanks. But I don't see where anyone talks about where the relay's are for the blowers..?
KyleR
2002 Carver 396
Re: Bilge Blowers
Postby KyleR » August 7th, 2023, 7:13 pm
On mine the relays are located right with the blowers (see pic). The relays are the little black square boxes between and above the blowers.
MV Verity
2002 Carver 396
mjmason1
Vessel Info: 1999 Carver Voyager 530
Has thanked: 2 times
Been thanked: 19 times
Re: Bilge Blowers
Postby mjmason1 » August 15th, 2023, 8:49 pm
When I had my 450, I had to replace all four blowers. I didn't want to deal with the relays, so I direct wired them. In order for them to work I had to flip on the breakers.
On my 530, again, none of the blowers worked. This time I replaced the blowers and was able to get the relays from a local auto parts store. Now they come on when the stbd key is turned to the accessory position. The relays are right with the blowers.
Users browsing this forum: No registered users and 52 guests
