halogen light replacement
- Agriman
- Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
- Has thanked: 5 times
- Been thanked: 5 times
I want to switch to LED bulbs. My current bulbs are horizonal in the fixture and so must be short enough to fit. Can anyone suggest the correct bulb with the two pin insertion?
Re: halogen light replacement
I believe you are referring to a G4 style bulb. Lots to choose from on Amazon. https://www.amazon.ca/s?k=g4+led&crid=C ... _sb_noss_1
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
I bought the Kindeep brand from Amazon to replace the halogens in the puck lights on my 356. A pkg of 10 was less than $15, of course, that was 3 years ago. Anyway, they are just slightly brighter and way cooler than my halogens. Halogens can burn your skin…LED’s, not even close to the heat. I highly recommend them.
Edit…I just looked up the Kindeeps and they are $16.50 for a package of 10. Whatever you buy, I strongly suggest getting warm white, in the 2700-3000 color temperature range.
Could not agree more.Whatever you buy, I strongly suggest getting warm white, in the 2700-3000 color temperature range.
- Agriman
Thanks guys, I hope they are short enough to mount horizonal in my fixtures. I seen DICUNO brand on Amazon for $18.99 ca.
for a pkg of 10. They are returnable if need be. Wattage is 1.5 watts.
- buster53
I’m guessing you have the same puck lights I have on my 2001 model. When I got my Kindeeps and looked at them, I was afraid they were too big, but they fit just fine.
- Agriman
Thanks to all, I have ordered the Kindeep G4. They gave a measurement that looks like they will fit.
- kgarguilo
- Vessel Info: 1999 Carver 406
- Has thanked: 197 times
- Been thanked: 55 times
I bought new fixtures and replaced them all form Walmart. They come in CW or WW. They look great and do not get hot at all. This link is qty 10 for $75 dollars by Dream-Lighting.
https://www.walmart.com/ip/Dream-Lighti ... /175500398
Kevin G.
1999 Carver 406
1999 Carver 406
