Santego 3867, Cat 3116, stuffing box size
bobwhorn
Vessel Info: 1989 Carver Santego 3867. Repowered with Cat 3116s in 1993.
Has thanked: 3 times
Post by bobwhorn »
Stuffing boxes are dripping, what size packing? Adjusting nut, RH or LH threads? Gave it a halfhearted try but lock nut didn't move. PB Blaster time or is there another way?
Thanks,
Bob
Been thanked: 1114 times
Re: Santego 3867, Cat 3116, stuffing box size
What kind of wrenches are you using? I bought the ones below at home depot and they worked great. You could add a section of pipe to get more leverage. You can also look at the actual threads to see if you're going the right direction (even stick a phone down there to get a picture or video close-up).
bobwhorn
Post by bobwhorn »
Looks like a great tool. The boat is a V-drive, can barely get a wrench on the nut, much less a pipe extension. Butit looks like it would get a much better grip than the tool I have. Thanks.
JimN
Vessel Info: '89 Carver Santego 38
Been thanked: 3 times
Post by JimN »
When you wrote 'lock nut', did you mean the large one or the thinner one?
FWIW, if you expect to do this more than one time, buy a wrench that fits, not an adjustable one. While pipe wrenches are better than the chrome adjustable ones, a wrench that fits is best. You shouldn't need a SnapOn or other expensive brand, but it needs to be able to avoid flaring at the end. The one that holds the other nut can be adjustable because it's just holding it in place, but I always preferred wrenches that weren't adjustable. YMMV.
bobwhorn
Post by bobwhorn »
The thin lock nut. I have one of those adjustable ones and its a PITA.
