Speed Curve
NIJORLES
Vessel Info: 1983 Carver 3607, twin diesel D225
Has thanked: 2 times
Speed Curve
Post by NIJORLES »
Hello, We have acquired a Carver 3607 at the end of the last season and I am trying to get some information about it. One particular question I have is the performance / speed of the cruiser at different engine speeds.
Does anyone have any info on estimated speed at idle, 1000, 1100 ..... 1600 rpms? Thanks in advance,
Re: Speed Curve
Welcome to the forum......you have a rare combo there I think. Only someone who has diesels like yours with the same props could be of any help. Gassers run in a totally different rpm range with different props and gears.
Hopefully someone with that combo or close could help.
Re: Speed Curve
Welcome aboard
Russdee
Vessel Info: 1984 Carver 3607
twin International 9.0L diesel
Re: Speed Curve
Post by Russdee »
Hi
Seems we have the same rare powerplants. I just purchase my 3607 late summer this year, and put about 40 hours on the boat since. Purred like a kitten. I don't know about the specific power settings you mentioned but here is what I had recorded:
Idle 3-4 kts
1000 rpm 6kts
1500 rpm 7-8 kts
1800 rpm 8-9 kts
2200 rpm 10-11 kts
2500 rpm 13-14 kts
Full throttle (done during the Mech Survey) produced 18kts
I have 22 inch props, Don't know the pitch as the Prop Speed polymer obscured the stamp, but suspect they are coarser pitch than the originals
Average fuel burn over those 40 hours was just over 10L p/hr p/eng. I am pretty happy with that as my speedy boat days are behind me :captain2:
Good luck with your new yacht
RD
Been thanked: 492 times
Re: Speed Curve
Post by waybomb »
Welcome aboard!
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: Speed Curve
Post by buster53 »
Just an FYI, either run the boat at hull speed or less, 7 - 7-1/2 knots or get up on full plane. Running in between those 2 speeds puts strain on the engines and wastes fuel….your MPG’s at 11-12 knots is probably less than at full plane.
