86 4207 Galley Bilge Pump Replacement Help
- Morningstar4207
- Vessel Info: 1986 4207 Carver Californian
- Has thanked: 19 times
- Has thanked: 268 times
- Been thanked: 1153 times
Re: 86 4207 Galley Bilge Pump Replacement Help
- Morningstar4207
- Has thanked: 455 times
- Been thanked: 1671 times
Have you done any diagnostics yet? Before installing another one, I would do a voltage drop test with the same load as the unit that failed to see if the voltage drops below acceptable levels. If it does, the unit would still work albeit at reduced efficiency but it's life would be shortened.
Are you taking on enough water that's causing the pump to cycle more often than expected?
- Morningstar4207
- Morningstar4207
- Morningstar4207
Users browsing this forum: No registered users and 54 guests
