'98 355 AC V-Berth Leak
- gmac98004
- Vessel Info: Proud new owner - '98 355 Aft Cabin "Invictus"
6BT5.9M 210hp
Formerly - 1986 - 30' Newport MKIII - Location: Shelter Bay, WA
- Has thanked: 253 times
- Been thanked: 12 times
I have been fighting this STBD side V-Berth leak for over a year now. With the rain we've had these past few months, it seems my situation has gotten much worse.
The photos I've included show a view looking aft from the STBD side of the V-Berth. The forward head is directly behind that maple bulkhead panel. Hard to see in the photos but the black mildewey area on the bulkhead panel is significant. So we're talking more than just condensation.
Last spring, I rebedded the cleat, 2 stanchion plates and the STBD running lights all of which are above that area in the photos.
After removing the bolster shelf and the upper valance with the curtains, I was able to rule out some things but not sufficiently diagnose where the water is coming from.
Some things I've been able to rule out:
1. The oval window seal seems to be fine. The foam wall covering was dry around that entire perimeter.
2. There doesn't seem to be any trace of dampness or water intrusion from the anchor locker.
3. Using a fancy new borescope with an articulating head, I learned that there isn't much dampness on the AFT side of the bulkhead panel although it is showing some mildew.....just not as intense.
4. There seems to be some buildup of moisture on the lip near the rub rail. This makes me very nervous!
5. Although I feel and see SOME condensation, the foam wall covering UNDER each of the stanchions seems relatively dry.
So............does anyone have any advice or perhaps you've experienced a similar issue? To make matters worse, the only snow we've seen in a couple years is due next weekend! No rebedding project anytime soon!
Lastly, I bought this gem on Amazon Thursday. It arrived yesterday in time for my discovery work today. The articulating head was a serious game changer for fussing with our boat challenges! The video display is crystal clear.
https://a.co/d/5OkJoSR
Many Thanks, Greg
- amyelias
- Has thanked: 1 time
- Been thanked: 4 times
Re: '98 355 AC V-Berth Leak
I haven't had that same issue but am familiar with all the possible areas where water could enter near that bulkhead. Based on all the rebedding/sealing you have already completed I would take a closer look at the rubrail especially since you did observe moisture there... I'm betting removing the rubrail, old sealant and replacing with new sealant will solve your problem.
Good luck!
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 18 times
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
Users browsing this forum: No registered users and 130 guests
