New Carver owner here can anyone tell me what this is?
Landlocked
Vessel Info: 1993 Carver 280 Sedan Flybridge
Postby Landlocked » February 20th, 2024, 3:50 pm
I purchased this carver 280 sedan and found a white box on the front of the flybridge that says "lowrance" on it. It seems to be to small to be any kind of radar.... the fishfinder that was with it is a "lowrance global map 1000" since replaced by a garmin. It would be greatly appreciated if anyone had any answers thanks.
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 474 times
Been thanked: 201 times
Re: New Carver owner here can anyone tell me what this is?
Postby pepmyster » February 20th, 2024, 5:12 pm
Not sure exactly but welcome to the group!
Been thanked: 1054 times
Postby km1125 » February 20th, 2024, 5:26 pm
I would guess that it's a GPS antenna. I'm thinking the "global map 1000" is a plotter, or has plotter functions in it.
What's the cable and connector look like?
And Welcome aboard!
Has thanked: 56 times
Been thanked: 444 times
Postby waybomb » February 20th, 2024, 7:34 pm
Welcome aboard!
My guess would be a GPS antenna.
Find the model number on the unit on the dash, search the Lowrance site for that unit, and look to see the picture of the antenna, just to be sure
Been thanked: 620 times
Postby g36 » February 21st, 2024, 10:26 am
Welcome, also here ya go.
Has thanked: 457 times
Been thanked: 1690 times
Postby Viper » February 21st, 2024, 9:37 pm
Welcome aboard
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 399 times
Postby Cooler » February 22nd, 2024, 11:32 am
Yes, that is a GPS antenna. In the late 90's, most GPS units operated with an external antenna. Depending on the Garmin model you have, it most likely has an antenna built into the unit. The Garmin unit might have a connection point for an external antenna, but I am not sure if that Lowrance model would be compatible. Check to see if the Garmin unit has this antenna connected to it. Might be causing the Garmin to act funky, or may be working fine. Welcome and good luck!
Where in Montana are you boating? 8-) er
Cooler By The Lake
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 153 times
Postby ColRon » February 23rd, 2024, 4:30 pm
welcome aboard
Ron
“Escape Plan”
Murray, KY
:usa:
