Mounting new Fireboy 375 CU FT fire suppression system
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Post by tonyiiiafl »
It was time to replace the original Halon horizontal Fireboy in the engine room on my 1994 390CPMY. However, no more halon, so it is some FK-5-1-12. It is longer and heavier, so there is no way it will fit against the forward bulkhead horizontally. It does say mouth vertically anyway. I have room in front to the port engine (454 Gas) that will allow it to go vertically. However, it would need to go into the outer stringer. I know they are all fiberglass. I was thinking of a 3/4” PT plywood, with 5200 behind it to anchor it against the stringer. It would be mounted right where the documentation number plate is in photo 2. Then use lag bolts to go through the plywood and stringer. Thoughts? Advice?
tonyiiiafl
Re: Mounting new Fireboy 375 CU FT fire suppression system
AND a couple houser batteries, AGM, 4D agm starting and a GRP 24 AGM for genset. A new Fireboy and an EPIRB to make the bride feel a bit better!
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 149 times
Post by KyleR »
Nice! We want to get that same EPIRB - but we've been crossing our fingers that West Marine (or some place) will put them on sale. They are always part of the "exclusions" on the West Marine coupons. :-(
MV Verity
2002 Carver 396
tonyiiiafl
Yes, even at DEFENDER and also at Hamilton Masrine in zMaine. That model is and was excluded. However, it will make the Admiral feel a tad more at ease when we head out, so for the automatic deploy,ent it was worth the extra $100.00
