Volvo engine exhaust elbow blowout
- HS Voyager
- Vessel Info: 1999 Voyager 53
Looking for help finding the parts I need for this repair. See photo. Also any suggestions as to how to clean up the soot?
Thank you
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 115 times
- Been thanked: 114 times
Re: Volvo engine exhaust elbow blowout
Rubber 90deg/45deg elbows and "hump" connectors can be found at the usual suspects: Defender, Jamestown Distributors, Fisheries Supply, etc.
I have had to replace both of my exhausts from the exhaust riser back to the muffler and these are the places I bought all my supplies. Hope it helps.
Not sure about the cleanup part! That looks pretty rough!!
https://inetmarine.com/
2002 Carver 396
- Been thanked: 1043 times
- Has thanked: 455 times
- Been thanked: 1671 times
I would check all your exhaust hoses and look for signs of overheating, inspect the insides of the hoses, and the rest of the fiberglass joints. Do you recall any alarms? How did you know you had a problem prompting you to check the engine compartment?
The soot should come off with a good strong cleaner but you're in for a lot of elbow grease. That stuff will be in every nook and cranny possible so chances are you'll never get it all. Pull your air filter and blow it out. re-use it for the first few hours of operation after the clean up but buy a couple of new ones and use them later. The filter will collect some more loose soot during the first few hours that you weren't able to get to, no sense in collecting that with your new replacements.
You should also consider setting up a portable compressor so you can open up electronic boxes like chargers, controllers, etc. that aren't fully sealed and blow out their insides as well as other items you can't get wet or wipe clean throughout the engine bay, engine wiring terminals, generator, etc. A strong fan at the cockpit engine hatch to exhaust anything you blow out will help move the particulates out of the engine compartment. Cover what ever you can topsides before doing that though.
- Been thanked: 615 times
- Has thanked: 579 times
- Been thanked: 1210 times
- Coldcruisin
- Been thanked: 6 times
Oil Eater
Spray Nine
Buckeye XL100
Sorry this happened. A lot of work ahead.
Users browsing this forum: No registered users and 262 guests
