1987 32 mariner A/C help
Ray.spahn
Vessel Info: 1987 32' Mariner Carver
Post by Ray.spahn »
When turned on the A/C unit pushes a lot of water under the cabinet where it is housed. The a/c unit is clean the pan is dry. Cannot get to anything else the unit is not in an ideal place. Trying to figure out where the water is coming from and why and how to fix it. I mean a lot of water when it is turned on. Thanks in advance. The manual I have is not helpful at all
Been thanked: 1114 times
Re: 1987 32 mariner A/C help
Sounds like you may have a hose problem and that water is coming from the HVAC water pump. You'll have to get in there and check those hoses and clamps.
