Lost Power to Vacuflush
- CLARKSON
- Vessel Info: 2006 Carver Mariner
I put a test light on the run/sleep switch and no power there... Can the circuit breaker just fail??? Its not tripped.. Is there another fuse? What could have failed. Never had a problem with this. Until now...
eric
- Alanna Mo Cree
- Vessel Info: 2003 360 Sport Sedan
Twin 8.1Gi Volvo Penta FWC - Location: Sanford, Florida
- Has thanked: 26 times
- Been thanked: 33 times
Re: Lost Power to Vacuflush
I don't have a run/sleep switch on mine, but if I suspected power issues I would check at the vacuum switch on the vacuum generator. On my boat that is port side of the engine room outboard behind the fuel tank. My dock neighbor has an older mariner and his vacuum generator is under the forward berth. The breaker for the system is also in the engine room, not on the panel with the rest of the breakers.
I recently rebuilt pretty much the entire vacuum generator side of the system because the pump would not shut off. By process of elimination it turned out to be the vacuum switch itself, which is a part that supposedly rarely fails. I'm not sure how it could fail in the always off mode though, since the vacuum generated is what sucks the switch out to turn it off.
2003 Carver 360 Sport Sedan
Twin Volvo 8.1Gi
Photo Album
- mjk1040
- Been thanked: 242 times
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 115 times
- Been thanked: 114 times
I've frequently been plagued by random electrical failures that turned out to be nothing more than corrosion or possibly a loose/broken connector.
Please let us know what you find.
2002 Carver 396
Users browsing this forum: No registered users and 48 guests
