Raritan Macerating Toilet splashing shi# out of the bowl
- cjblovinlife
- Vessel Info: 1996 Santego 380
- Has thanked: 27 times
- Been thanked: 8 times
It was working fine for the four months or so that I have the boat and then all of a sudden one day just started splashing out of the bowl and onto the floor. I changed the Joker valve expecting that to correct the issue and it did not any ideas??
- Been thanked: 1312 times
Re: Raritan Macerating Toilet splashing shi# out of the bowl
Maybe the discharge line to the tank is clogged,..... idea two....tank vent plugged.
Ya check what bud suggested. I know you said you replaced the joker valve but that symptom points to the valve allowing backflow which is what it's supposed to prevent. There may be something caught in the valve and blocking it open or the valve got twisted/distorted during installation which is not uncommon.
- cjblovinlife
Thank you I’ll check your suggestions Saturday
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
What are you using for tank deodorent? Need to use fluid only. The bags can clog up the line. I once had an issue with bowl not emptying. I ran the flush system for a few good long flushes. cleaned itself out and has been working fine. Gotta hold that button in flush mode for a good 10 seconds.
er
Cooler By The Lake
Start with a pump out that should clean the discharge line....you can hear the air being sucked thru there then pour fresh water thru. At least that will get you started in the right direction.cjblovinlife wrote:QR_BBPOST Thank you I’ll check your suggestions Saturday
Yes, as Bud says, make sure the holding tank is not full. If it is there is nowhere for the waste to go.
