366 water line
- Carverlvr2
- Been thanked: 3 times
366 water line
- Has thanked: 580 times
- Been thanked: 1210 times
Re: 366 water line
Inside the hull the hose may have a loop up but that wont help if the fitting itself fails. Is it plastic ?
- Carverlvr2
Re: 366 water line
Re: 366 water line
Just might give you a comfort zone for thinking and leaving the boat alone. Worth a try.
Hopefully someone with the same boat and thruster can chime in.
- Carverlvr2
Re: 366 water line
- Has thanked: 456 times
- Been thanked: 1671 times
Re: 366 water line
- Has thanked: 269 times
- Been thanked: 1153 times
Re: 366 water line
Some manufacturers put HVAC discharges low to minimize discharge noise.
Both my front and rear AC discharges are 1/2 submerged from the factory, only wish my center discharge was also as it does make noise and causes stains on the hull.
Hmmm, could turn into a new project.
My dock neighbours boat (Cruiser Yachts) has 2 side discharges that must be at least 3 1/2' above the water line and shoot out about 4 to 5 feet from the boat, talk about noise and a stupid design. No way could he run AC while docked on his starboard side.
- Has thanked: 324 times
- Been thanked: 595 times
Re: 366 water line
- Carverlvr2
Re: 366 water line
Re: 366 water line
Carverlvr2 wrote:Source of the post I was mostly concerned with the soon to be freezing temps
That is a very valid concern and good on you to address it as you could. The difference is, your boat is in the water for the winter as many others are hauled out so where that fitting is located can mostly be a concern for noise control.
Imo .....Any side hull discharges, if not easily accessible , should not be so low as to be able to take on water in normal circumstances with no way to easily access the leak, or even check for a leak.
