Novakool fix or live with?
Carverlvr2
Been thanked: 4 times
Postby Carverlvr2 » January 26th, 2025, 10:53 pm
Howdy all! During the survey on my ‘04 366, we found the Novakool RFS7501 ac/dc side by side fridge freeze runs well but is only running on dc. I’ve read the 101N0510 controller is the common failure on these and easy enough to replace but is a $300ish part going into a 20yr old fridge. Is it worth fixing or just deal with it till the whole thing dies? If it only worked on AC, this would be an easier decision…gotta keep the bevy’s cold on the hook! With it constantly running on dc, I have to imagine that’s wearing on (I’m assuming) the house battery bank? Looks like the replacement fridge is $1800+…how long do these generally last? What are your thoughts?
Has thanked: 457 times
Been thanked: 1675 times
Re: Novakool fix or live with?
Postby Viper » January 27th, 2025, 8:52 am
I'd be okay with just the DC side working. Anytime you're at the dock, the charger is topping up the banks so the fridge doesn't really deplete them, and the engines do that while you're underway. On the hook you're on DC anyway for the most part and if you turn on the genny for anything, the charger will help bring the bank back up.
If only the AC side worked you could still have the effects of what I mentioned above by simply plugging the fridge into a dedicated inverter. Then you're just maintaining the DC bank as I mentioned.
Has thanked: 582 times
Been thanked: 1213 times
Postby bud37 » January 27th, 2025, 9:49 am
Considering the fridge is old and having issues....My advice before you decide what to do, get yourself a fridge thermometer to check whether it is keeping your perishables at a safe temp. If it isn't it is unsafe to use for food and could make you or your family sick. That might make your decision easier.
Has thanked: 269 times
Been thanked: 1155 times
Postby Midnightsun » January 27th, 2025, 11:05 am
Call Novakool while you are at the boat and they will determine what is wrong by helping you troubleshoot/test. Never seen such helpful and friendly service. In general, those fridges are among the best and easily repaired.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 394 times
Postby Cooler » January 27th, 2025, 12:23 pm
It should have a plug for the AC side. Check to see it is plugged in. The original fridge in my Mariner puked out after 21 years. Replaced with a new in 2017. Runs so quiet I can sleep right next to it with no cycle sounds. The 1800 was worth it for me. Just FYI, the alternators on your Crusaders are heavy duty, so they are generating power. Good luck! 8-) er
Cooler By The Lake
Carverlvr2
Postby Carverlvr2 » January 27th, 2025, 3:05 pm
All great feedback! The fridge thermometer is an excellent place to start but will have to wait a few months as it’s so cold here right now, the fridge doesn’t even need to be on to keep things frozen! lol. It’s sounds like these Novakool are good fridges but is 20yrs a pretty good run for these? When I was boat shopping, nearly every one I looked at in this age range all had replaced that same fridge with the same model but either black or SS panels.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 118 times
Been thanked: 115 times
Postby KyleR » January 27th, 2025, 3:28 pm
I'll second this! We had a mysterious leak in our V-berth near the shower door and couldn't find anything. Eventually, by chance I was looking behind and under the refrigerator because it didn't seem to be working so great at keeping things cold. That's when I noticed standing water, which lookd like it was possibly the source of our leak. More digging revealed that the insulation on the pipes in the back had worn out and come loose in many sections causing ice to build up and subsequently melt causing the "leak"!
I was very close to replacing it but but I called NovaKool to see if there was any hope. The guy told me what to do and some suggestions on what products to use and he said it would be like a new one and I'd probably get another 20 years out of it! He said he often sees ones lasting 30-40 years! I'm not sure if that was just hyperbole, but I made the repair over a year ago and not a drop of water since - and it is staying colder and working better than ever!
Kyle
MV Verity
2002 Carver 396
Carverlvr2
Postby Carverlvr2 » January 27th, 2025, 3:53 pm
Thanks! That gives me Hope that there’s possibly several more years left in it! And yes, I’ll give Novakool a ring next time I’m out there and make sure that’s the part I need and maybe some other improvements while it’s pulled out. “Saving money in boating?” Is that even a thing? Lol
Alanna Mo Cree
Twin 8.1Gi Volvo Penta FWC
Has thanked: 30 times
Been thanked: 35 times
Postby Alanna Mo Cree » January 29th, 2025, 7:04 pm
Carverlvr2 wrote:Source of the post “Saving money in boating?” Is that even a thing? Lol
Nope. ;-)
Charlie & Jennifer
2003 Carver 360 Sport Sedan
Twin Volvo 8.1Gi
Photo Album
Return to “Electrical”
Users browsing this forum: Carverlvr2 and 14 guests
