Boat Stink: The tale as old as time
- Vessel Info: "BAD MONKEY'
1999 445
Cummins
Safe Harbor Ventura Isle
Ventura, CA - Location: Ventura Harbor, CA
- Has thanked: 10 times
- Carverlvr2
- Been thanked: 4 times
Re: Boat Stink: The tale as old as time
- Has thanked: 582 times
- Been thanked: 1213 times
Alastair MacGregor wrote:Source of the post Frightened that it may be the line from the pump to the grey water holding tank for the Fwd head
If you want to check waste lines for permeation a good test is to take a warm damp rag and wrap it round the hose in question , leave for awhile then take it outside and sniff, you will know. Good luck man.
Oh to add , once the hoses are permeated my understanding is there is nothing that can save them other than new hoses unfortunately.
- buster53
- Been thanked: 262 times
- Carverlvr2
See the thing is, you really have no idea what someone before has added to that system or how long it was left untreated, could have already damaged the inside of lines. You could spend months trying this or that or a couple hours and just replace the lines with new and have done with it. I know sometimes it is difficult to do but when it is done.....nice !
Pump out suction hose ...Tip.....because waste sits in that line as the tank fills it makes that section of hose particularly bad, put PVC pipe the last couple feet to the tank where the pump out waste hose attaches to the tank if your tank is evacuated from the bottom side. Better ones have fittings that go thru the top, they are ok.
- Alanna Mo Cree
- Vessel Info: 2003 360 Sport Sedan
Twin 8.1Gi Volvo Penta FWC - Location: Sanford, Florida
- Has thanked: 30 times
- Been thanked: 35 times
2003 Carver 360 Sport Sedan
Twin Volvo 8.1Gi
Photo Album
1999 445
Cummins
buster53 wrote:Source of the post Just an FYI, you mentioned gray water tanks a couple of times. Gray water is discharge from sinks and showers…black water is discharge from heads. The two should never come in contact with the other.
Sorry, black water tank. the smelly one
1999 445
Cummins
bud37 wrote:Source of the post I have tried that stuff, expensive and for me, did not notice much of anything, certainly didn't clean up the tank.Let us know if it works for you.
Thanks, much appreciated
1999 445
Cummins
