350 Aft Cabin Hydraulic Steering Pressure
- Captain Sid
- Vessel Info: I'm looking for more information on Carver Yachts before purchase.
- Has thanked: 71 times
- Been thanked: 1053 times
Re: 350 Aft Cabin Hydraulic Steering Pressure
If the pressure is low, you can top it off with a regular bike pump or small tire compressor. Don't exceed max pressure though.
If the system continually loses pressure, then you have a leak somewhere, which should be found and fixed before it does become a problem with controlling the vessel.
- Has thanked: 457 times
- Been thanked: 1685 times
- Captain Sid
- Has thanked: 583 times
- Been thanked: 1225 times
Captain Sid wrote:Source of the post During survey the surveyor found that the steering pressure was at 10 lbs. I understand that it's supposed to be 20-25 lbs. I didn't get to see what he was looking at, but pretty sure he saw a gauge. Question is how do you increase the pressure in the system?
Just noticed this.......One thing to note here, an old pressure gage can give the wrong reading, I would double check the system with a known good gage then you can be sure of any repair being at the correct pressure.
Users browsing this forum: No registered users and 61 guests
