2000 Carver 506 - Rear Port Shore Power
- KuyaJunGarage
- Has thanked: 5 times
So I pulled out my voltage meter to read the voltage on my “AC Selector Switch”. Anyone know where to start or had this issue before?
I do get power with front shore power port and that is working fine.
Many thanks in advance.
- Has thanked: 585 times
- Been thanked: 1231 times
Re: 2000 Carver 506 - Rear Port Shore Power
- KuyaJunGarage
thanks again
KuyaJunGarage wrote:Source of the post thank you bud37 for the quick reply. much appreciate it. I did check the breaker it didnt' trip but i need to check the voltage see if both black and red are getting 110v.
thanks again
You have power from the shore pedestal , correct....is it the same one you are using for the front shore receptacle on the boat ? Is this your home marina where there has been no issues before ?
Sorry lots of questions, just trying to cover the shore side first.
- Cooler
- Has thanked: 68 times
- Been thanked: 400 times
- KuyaJunGarage
Yes there is power from the shore pedestal.
running the FRONT shore power no issue, I have power in the boat.
I"m still learning the boat just bought it, (17 hr trip to take it home). Is the shore power pass through the inverter?
IF yes, you guys think i have to hard reset my inverter/xantrex?
thanks
Oscar M
See the thing is , one never knows what previous owners/mechanics have done prior, so ya have to pick thru things carefully. If all the circuits work as normal with the gen and front power connection then perhaps the other plug has an issue.....corrosion, loose connection etc etc. transfer switch connection .....does your boat have an isolation transformer installed.
Sorry I am not familiar with all shore power going thru an inverter.
Good luck man, hope you find it and be careful with power.....if not experienced get a certified marine electrician.
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 39 times
- Been thanked: 20 times
- Has thanked: 72 times
- Been thanked: 1055 times
Take some pics of what's back there too.
You could also do the same at the aft shore power inlet and where the breakers are located for that aft inlet.
- KuyaJunGarage
Anyone know what size circuit breaker I need
It’s a carlingswich breaker
