Vacuflush Toilet Seal Recommendation
Post by Midnightsun »
I installed these in both heads 10 years ago. This season our master head started a slow leak causing the water to empty out of the bowl and consequently activating the suction pump. Nothing serious however the pump would kick in every 3 hrs or so.
Knew exactly what the problem was so I dug out the spare and put a new one in, about a 15 minute job at best.
Just saying you do not need to pay $70 for a Dometic brand when you can get 2 for 1/3 the price. Lasted 10 years so the quality is definitely there.
The teflon style spacer is a big improvement on the rubber spacer Dometic uses
Just check to see if they list your vacuflush unit for fitment.
https://www.amazon.ca/dp/B0C6XVC17W?ref ... asin_title
