Hi All,
I have a Kohler 10E in my 396. It has a Ford VSG-413 4 cylinder gas engine with a build date of 2002. The generator has low hours on it and is in great shape except for one thing. One of the exhaust valves rusted into place slightly open, probably from lack of use before I bought the boat. I removed the head and a machine shop got the valve out, but it is damaged. The head itself is fine. Finding parts for this engine (other than some tune-up parts) is very difficult. Kohler has discontinued most parts for this engine. Their list prices for some of the parts (they don't have) is 10X-20X the typical price from a distributor. This engine was used in other applications such as Bobcats and skid-steers. I have tried industrial and farm sites. I found a few items but no valves or push rods. I think I have a line on a head gasket set as a custom order from Clevite through Jegs. We'll see if it actually shows up. I also found a site in England (MotorDoctor.co.uk)that has parts for Ford cars which share some of the parts, but their shipping to the US is quite expensive (although way less than a new generator) I am going to contact them to verify if parts for the J6B Ford engine found in older Fiestas will fit the VSG413. The valve specs are identical. I have placed an order for a custom valve from Manley Performance to replace the bad one, but I can't find a replacement pushrod. Has anyone run across a source for parts for this engine? I hate to replace a genset that could run for many hours with a few bucks in parts. Several sites list parts for this engine, but most don't actually have stock and can't get the parts. I will share any sources I find. I 'm sure somewhere there's a warehouse with a bunch of new old stock or replacement parts that is just not accessible through internet searches. I hope we can pool some knowledge and avoid spending $14K on a new replacement.
Kohler 10E (gas) engine parts (Ford VSG413)
Re: Kohler 10E (gas) engine parts (Ford VSG413)
It might help if you posted a spec and serial number. To clarify, you have sourced a valve and are looking for a push rod, correct?
- thatchh
- Vessel Info: 2004 Carver 396ES gas Crusader 8.1
- Has thanked: 5 times
- Been thanked: 11 times
Correct, I am looking for a pushrod. It would be nice to know if there is a source for valves as well for future reference.
My generator is a Kohler model 10E-CB3 serial number 0776619 spec number GM17772-GA2. The engine serial is 03-09-060495 and the base engine code is P89BF-6005-BE.
- dscalarm
- Vessel Info: 2003 Carver 396 motor yacht
twin 8.1 Volvo Pentas. - Has thanked: 8 times
Hey there I have a 2003 396. It appears that I have the exact same generator and I'm looking for some hoses and maybe a heat exchanger. And maybe some of those parts that cause it to shut off because it used to start. OK, and now it shuts off after running for a minute or 2. I had a friend who just removed some of the hoses and that's where it's been sitting for a couple of years.
- dscalarm
- dscalarm
By the way, thanks in advance for any help. This site has been tremendously helpful over the years.
- Been thanked: 654 times
Please keep us updated with what your finding and suppliers. I also have a 10E with the Ford engine.
- thatchh
When I was working on mine, I discovered that the thermal cutoff sensor on the exhaust elbow had broken at its stud mount. I could see that causing possible cutout after running for a short time. You could also have a water pump failure or a clogged cooling line that causes that sensor to trip if it's intact. You should be able to put your hand on the exhaust elbow and have it feel cool. If it's hot, or even very warm, you may have a cooling system problem.
BTW, If your generator has been sitting for a couple of years, I would recommend you pull the valve cover off and push on all the valves to make sure they haven't corroded in place.
