3 weekes later here is a pic of the inside. It was leaking from around the shaft
Need advice for seal replacement
- Punch'Eau
- Vessel Info: 2000 350 Mariner
- Has thanked: 25 times
- Been thanked: 7 times
Re: Need advice for seal replacement
- Been thanked: 1114 times
Yea, that's a regular stuffing box. Loosen the jamb nut and tighten down the large nut a bit and it'll likely stop the leak. That stuffing doesn't wear out nearly as quickly as the prop shaft (obviously because the rudder shaft isn't spinning!), so it's likely that all you need is some adjustment.
- Punch'Eau
Thank you very muchkm1125 wrote:QR_BBPOST Yea, that's a regular stuffing box. Loosen the jamb nut and tighten down the large nut a bit and it'll likely stop the leak. That stuffing doesn't wear out nearly as quickly as the prop shaft (obviously because the rudder shaft isn't spinning!), so it's likely that all you need is some adjustment.
