Engines smoking but running well
sonnyb
Vessel Info: 1977 santa cruz 2566
Re: Engines smoking but running well
Post by sonnyb »
if you said what type engines, i missed it. chevy,s are really bad to get oil drain holes plugged up. pull the valve cover and look at the back lower corner of the head. you,ll see a drain hole about 3/8 or so. run a screwdriver or something through it and clean it out. what happens is, when running, oil builds up in the valve covers and get pulled down through the valve guides. chevy,s have gotta drain !
Seif911
Vessel Info: 1977 Carver Mariner 33'
Been thanked: 4 times
Post by Seif911 »
They are Chevy's, OMC's, 350's. That'd be a nice and easy fix.
Thanks,
Steve
