Mystery
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Mystery
Post by feeez »
When we arrived at our boat this week my shore power 1 breaker was off. No damage done. I checked my energy monitor and there had been very little usage so it had just happened. We left the boat for several hours today and when we return the breaker had tripped again. When I when to reset it the reverse polarity light blinked and the breaker again tripped. I checked all of the shore power cords and they all seemed secure but I unplugged and plugged them all in again and the breaker reset no problem.
Any tips or trouble shooting would be appreciated.
Fraser
Former 2001 350 Mariner owner
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Re: Mystery
Post by Lyndon670 »
Can you switch to another power pedestal Fraser? Maybe its not your boat but the supply...
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Re: Mystery
I agree with Lyndon. Try that, it's the easiest check. Other possibilities are your inlet, your cord, your breaker, or wiring. The chances of both cords doing the same thing at the same time are small so try switching the two cords to see if the fault fallows #1 cord. When this happens, are there any symptoms on line 2?
After Taxes
Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada
Has thanked: 6 times
Been thanked: 17 times
Re: Mystery
Post by After Taxes »
Agree with Lyndon. Another boater is drawing too much and tripping your shared circuit. Happened to me.
MerCruiser MX 6.2
Lake Simcoe, Ontario
Re: Mystery
Post by tomschauer »
I had a very similar problem a few years back, misc trips and occasional reverse polarity light. After checking everything including the connections at the breakers on the boat I pulled the shore power inlet connectors out and the neutral wire on the connector that connects to the main breaker was a bit toasty and loose. Cut, strip, new crimp all was well.
Been thanked: 248 times
Re: Mystery
Post by mjk1040 »
Sure sounds like a bad neutral to me! Mike
