Refrigerator Working on Battery Only - Carver 3207 Aft Cabin
acevesc
Vessel Info: Carver 3207 Aft Cabin | YR 1983
Gas Engine: Twin 350 Crusaders | 6.5 Genset Onan Generator
Home Port: Umatilla, OR
Has thanked: 3 times
Post by acevesc »
Who should I call?
Plugged into dock electrical. My refrigerator works on the battery only and when I tried to plug its cord into electrical socket it trips my outlet. Should I call an electrician or refrigerator technician?
Now the fridge is the original with boat so its 30+ years old but still would like to get it fixed.
Connie Acegal
Re: Refrigerator Working on Battery Only - Carver 3207 Aft Cabin
Sounds like the power supply on the fridge. Check for a blown fuse on the power supply, some do have one and may indicate that there is a short in the circuit. Before you go any further, try plugging it into a different outlet but use a decent heavy extension cord, preferably one that is not very long. This would eliminate the possibility of a weak breaker. If it trips the breaker for the different outlet, the issue is at the fridge end.
gmwalley
Vessel Info: 1994 Carver 370 Aft Cabin
Been thanked: 11 times
Post by gmwalley »
What kind of fridge? I am in process of swapping out my Norcold DE560 (dead compressor) but all the power supplies still work fine. Make you a good deal if it will help get another season out of it.
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Post by AaHubb »
I did the same as gmwalley this spring for the same reason. If you need parts I'm a little closer to you. Although if yours was original mine would be a lot newer model.
..Aaron
'99 404 CPMY
SeaDragon
