Kohler generator voltage drown when load applied
Been thanked: 622 times
Re: Kohler generator voltage drown when load applied
Postby g36 » August 10th, 2017, 8:32 pm
Its the service manual. If yours states owners it's not the same. Also the manual number on the front is TP 5414 look on the front of your manual and verify it's not the same it should be different if it's a owners manual.I'll also chrck my owners manual for the number.
dsolo
454 EFI Crusaders
Name: La Belle ll
Been thanked: 25 times
Postby dsolo » August 10th, 2017, 9:42 pm
Thank you g36. The tech has the manual, I will check with him.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Postby g36 » August 10th, 2017, 10:12 pm
i have the tp-5313 parts manual i can email if that would be of any help. im not sure if i am correct but i think we have a ford vsg 411/413 engine on the genset. i have that service manual i can email you too.
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » August 11th, 2017, 2:31 am
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Postby g36 » August 11th, 2017, 7:31 pm
dsolo check your email
DanM
Vessel Info: Carver 396
Has thanked: 5 times
Been thanked: 33 times
Postby DanM » August 14th, 2017, 6:12 pm
dsolo,
I had this same issue with my 2004 10E Kohler in 2010. After much trouble shooting it turned out to be the Governor Controller Board. I made the mistake of purchasing it from an electrical supply house who said they were an authorized dealer but in reality was not supposed to sell it to an end user, and for good reason. It needs to be programed prior to installation and they didn't offer that service. After speaking with Total Energy Systems (not the organization I bought it from) they offered to program it for me. I had it back less than a week after I shipped it to them. It solved the issue and the generator has been running fine ever since. Total Energy really stepped up when they didn't have to. ---> :worthy: BTW they also had me clean and reset the flywheel pick up sensor. Even though it was not the issue they felt it should be done as a matter of course.
Dan
Carver 396
SugarSand Tango
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » August 20th, 2017, 1:42 pm
Thanks for the information regarding the governor PCB. I am waiting to hear whether the mag-pickup is good. Marina had to order a 1K resistor, which took a week to get?? I also had to provide the test procedure to them. They know very little about Kohler gensets.
I suspect the governor PCB is bad. I should have results of the mag-pickup test Monday. I found a used PCB on eBay for $87. The seller can't garantee it, but will refund the$$ if found to not work. It is the original assembly and will not require programming.
I will take your recommendations on Total energy if needed. Are they listed on the website as a Kohler dealer?
Dan
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » August 22nd, 2017, 10:50 am
Tested the speed pick up component. Applied 12 vdc with a 1K resistor in-line. Passed a metallic object across sensor and read open. No voltage at all. Net mag-pickup is $200 usd. Wish I knew the Honeywell part number, I am sure it is in the $30 range. You gotta love boating to put up with the price gouging.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » September 14th, 2017, 8:28 am
Just an update on the generator repair. Purchased the speed pick up from Kohler. Paid the $200 usd and waited a week for delivery. Fortunately the sensor was the problem. Up and running. Thanks for all the good input and manuals. Love this forum. Dan
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
