Kohler generator voltage drown when load applied
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- mjk1040
- Been thanked: 243 times
Re: Kohler generator voltage drown when load applied
- Has thanked: 585 times
- Been thanked: 1231 times
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Has thanked: 458 times
- Been thanked: 1699 times
- dsolo
454 EFI Crusaders
The mag-pickup sensor is a normally open component so the open reading across the connectors is normal. There is a method to test it, it requires applying+12 vdc to it and putting a 10k ohm resistor in-line. You must pass a magnet across the sensor and measure the voltage drop across the resistor. I will check with the tech about testing it.
I am beginning to think the pcb assembly is suspect??
It is difficult getting help from Kohler. The marina is not a authorize dealer. The closest service is 100 miles away.
Will keep you updated.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Been thanked: 622 times
http://www.partsfortechs.com/asapcart/t ... p-808.html
- dsolo
454 EFI Crusaders
Is this manual different from the owner's manual? I do have it. I first thought the manual I have did not cover the 10e, someone corrected me stating there was no difference between the 10c and 10e. The manual I have is labeled 8c & 10c.
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
