Thanks guys!!!
How often should vacuflush pump run?
- Dark Horse
- Vessel Info: "Dragonfly"
2001 Carver 350 Mariner
Twin 350 MAG MPI - Location: Hudson, FL
- Has thanked: 1 time
- Been thanked: 6 times
Re: How often should vacuflush pump run?
Ok tightened all the hose clamps I could find on the system and it seems to have fixed the issue.
Thanks guys!!!
Thanks guys!!!
" The trouble with trouble is it usually starts out as fun!"
2001 350 Mariner w/ 350 Mercruisers
Home Port - Hudson, FL
- soupycamp4@yahoo.com
- Vessel Info: 1987 carver 3607
Hello Everyone !
My name is Scott and i am a new carver boat owner, I have a carveer - 1987 - 3607 aft cabin cruiser. I am noticing the air conditioning pump is constantly running for fresh water cooling but i am not getting any cooling from any of my heat pumps. If i was to put a set of gauges on the system what should i expect for pressures when it operating correctly ??
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 21 times
Midnightsun wrote:Qr Bbpost My experience is the duckbills need to changed every 10 years or you will have issues. I have noted every 8 years now so I do not have to deal with a problem as opposed to preventative maintenance which can be done when you feel like it and when you have the time not to mention it gives you plenty of time to locate them a a really good price. I carry a complete set of duck bills for each head on board just in case.
As for the head being on or off when away from the boat I guess off or "sleep" is the best way to do it. I do know when we return there is still a vacuum in the system after a week.
Are these fairly universal? one size fits most? if so, do you have part number handy? I believe I should have spare handy as well.
- Cliffm
"the Condo"
Dark Horse wrote:Qr Bbpost Ok tightened all the hose clamps I could find on the system and it seems to have fixed the issue.
Thanks guys!!!
good to know, as it will be my "first" approach as well now.
- Been thanked: 654 times
The Sealand s series vacuflush is a 1 1/2" duck bill theres 4. Part number
385310076
385310076
Thanks guys!!!
Awesome. You know a bit more about your vacuflush now, glad it was a easy fix.
Yup its either that or whatever was stuck in the duckbills removed itself.........
Had this boating friend who swore by this particular head treatment, it was a granular tablet that dissolved.....anyway every time we used it the vacu would act up until the bits worked their way thru.....hmmm
You could always dissolve the granular treatment in a glass of water then pour it in the head that way no bits to get stuck.
It was dissolved first , really just showing an example that even little things that seem insignificant can affect the proper operation.....does not always have to be something big.
- Gator
- Vessel Info: 85 carver 36 aft cabin
Just replaced my vacuflush with jabsco quiet flush the vacuflush were replacing parts all the time got tired of it and they use a 1 inch hose so it’s easy to run easy install
