WINTERIZATION...the "W" word
Has thanked: 456 times
Been thanked: 1671 times
Re: WINTERIZATION...the "W" word
Postby Viper » September 8th, 2020, 6:34 pm
You don't have to warm up the engine first. You'll still get AF into a cold empty block with the t-stat in place. Like you said though, if in doubt and it makes you feel better, pull a plug afterwards to check for AF.
tonyiiiafl
Has thanked: 601 times
Been thanked: 190 times
Postby tonyiiiafl » September 8th, 2020, 6:50 pm
When I had RWC engines, I drained, took temp sensor out and filled block, Then drained and filled again.. Thhe did same to manifolds. ALWAYS poke about with a coat hanger wire to make sure rust doesn’t block passages.
Users browsing this forum: No registered users and 119 guests
