Cliffm wrote:Source of the post So.... Plot thickens! Pulled under dash panel to access backside of horn mount wiring, looked good, so I removed dash panel to access horn rocker switch which turned out to be a relay switch. so I tried it and horn blew?
So, the $100 question. Is my "old" Marcinco AFI trumpet horns being temperamental/going bad... or is the horn "relay" rocker switch going bad when used "allott"?
Any EE's having insight to my dilemma?
Trumpet horns stopped working today
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
Re: Trumpet horns stopped working today
- Has thanked: 585 times
- Been thanked: 1231 times
- Cliffm
"the Condo"
- Has thanked: 260 times
- Been thanked: 19 times
Nharrison5 wrote:Source of the post You mentioned fog. Mine went bad after I washed the boat one day. I had read that spraying a little WD40 would cause the horn to blow. It did. The horn failed the next time it rained. I replaced the horn and it works fine now. They are evidently more sensitive to water as they age.
Thanks, thinking that after finding our helm stereo speakers having severely deteriorated cones, and replacing them this weekend.Cliffm wrote:Source of the post So.... Plot thickens! Pulled under dash panel to access backside of horn mount wiring, looked good, so I removed dash panel to access horn rocker switch which turned out to be a relay switch. so I tried it and horn blew?
- Cliffm
"the Condo"
went to WestMarine, bought the Marinko 12V 123db pair, swapped out, sounds great!
appear to be the same make as previous OEM installed units, hoping they last as long.
