Ignition Switch
Has thanked: 585 times
Been thanked: 1231 times
Re: Ignition Switch
Postby bud37 » March 9th, 2021, 6:55 pm
Wsullivan71 wrote:Source of the post Thanks everyone, appreciate all of your tips! I will let you know what I find once I get back to the boat next month.
That will be great to hear what you found...thanks...
Wsullivan71
Vessel Info: 2001 Carver 404 Motor Yacht
Been thanked: 11 times
Re: Ignition Switch
Postby Wsullivan71 » June 21st, 2021, 12:48 pm
Update on my starting problem....Viper was 100% correct. Both starter solenoids were bad. I changed them out and both engines started right up! $37 part so worth carrying a spare.
Has thanked: 457 times
Been thanked: 1697 times
Re: Ignition Switch
Postby Viper » June 21st, 2021, 10:15 pm
Thanks for the update. Yep, that's the slave solenoid, pretty common failure. This will help others experiencing the same fault later. :down:
Dewmyster
Vessel Info: 1998 370 Voyager
Been thanked: 12 times
Re: Ignition Switch
Postby Dewmyster » June 29th, 2021, 10:35 am
My problem was finally resolved when I followed Viper's instruction on replacing the slave solenoid. Thank you Viper :down:
:usa:
Re: Ignition Switch
Postby Viper » June 29th, 2021, 10:04 pm
:down:
Users browsing this forum: Google [Bot] and 28 guests
