SOLAR PANEL INSTALLATION
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Re: SOLAR PANEL INSTALLATION
Those are the same as I have. Once you check out photo 2, same situation, Marked POS POS in, and NEG NEG out. Don’t quite understand that. However, I am running 4 panels,, 2 each hooked in series, then joining the 2 in series in a parallel manner, so these will work, just confusing as all Hell!
- tonyiiiafl
Also, here is the installation better than 1/2 done. I am surprised, but those panels are SOLID! Full cure in another 12 hours, but they do not budge! I have a cubby on my 390 behind the couch where the central vac is, I am going to tuck the MPPT charge controller in there. I am also going to place a disconnect switch before and after the controller. Over kill for 2?
That stands for "piece of $hit" and "no effen good". Got to buy some of the good stuff.
- tonyiiiafl
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Your panels mounted with 4200 are going no where. My friend had to move 4 elevator bolts this week end to install a new panel. He had a hard time getting the mounts off to move them. Mine are mounted the same way and I have had no issues.
The install looks great.
Greg
Greg
- tonyiiiafl
- Been thanked: 654 times
Thanks for keeping the updates and pics coming
Great job Tony, can't wait to get some real life operating numbers from you.
- tonyiiiafl
Put it on line today. Very impressed. I shut shore power, and ran from batteries. ALL day, fridge was working, toilet and water pressure pump, inverter for coffee. Batteries stayed at 100%. Controller, went up, down, and kept up with the load. Next weekend a weekend away on the hook.
You da man......nice...have fun with your new boat...and thanks for posting your progress as this will help others down the road I am sure.....
