cooling issue
pepmyster
8.1 Volvo Penta
Fresh water boating
Been thanked: 201 times
Re: cooling issue
Postby pepmyster » June 16th, 2023, 1:29 pm
Welcome! Glad it worked out!
hamidm
Vessel Info: 2005 Carver 36 Mariner. AOL: 37 feet. Vertical length around 14' 1". Beam: 12' 9". Draft: 37". Twin engine Crusader 5.7 liter. 320 HP each. 170 hrs on both engines.
Re: cooling issue
Postby hamidm » May 13th, 2024, 3:10 pm
Hi everyone,
It's been a while since I asked for your help.
I have an issue with my port side engine!!
Black smoke comes out from the exhaust for about 30 seconds then stops. This happens only on cold start.
Please help me out if possible. I truly appreciate it.
Thanks again for your previous help.
Been thanked: 1055 times
Re: cooling issue
Postby km1125 » May 13th, 2024, 5:17 pm
hamidm wrote:Source of the post Hi everyone,
You really should start a new thread for a new problem, or you might get confusing answers as some folks would reply to the initial problem or get the symptoms confused with the new problem. That said, these are port fuel injected engines, correct? Have you looked at the spark plugs for the engine?
Users browsing this forum: No registered users and 191 guests
