cooling issue
- hamidm
- Vessel Info: 2005 Carver 36 Mariner. AOL: 37 feet. Vertical length around 14' 1". Beam: 12' 9". Draft: 37". Twin engine Crusader 5.7 liter. 320 HP each. 170 hrs on both engines.
- Has thanked: 1 time
cooling issue
I have a 2005 Carver 36 Mariner with two 5.7 liter Crusader engines. Starboard engine's cooling system has air in it that is causing over heat!! I would like to bleed the air out but do not know how to do it! Please help me out and let me know what the procedure is for bleeding out the air from the system. If you know of any videos or picture please send them to me. I can not thank you enough.
Thanks,
Hamid
- Has thanked: 72 times
- Been thanked: 1055 times
Re: cooling issue
And second... are you sure you have good impellers in the raw water pumps?
- waybomb
- CYO Moderator
- Has thanked: 57 times
- Been thanked: 445 times
Re: cooling issue
Somebody with more experience than me can help with the crusaders. I've heard of this issue on these engines.
On a couple of my cars, with separate cooling and intercooling systems, I must use a vacuum system to fill them. That may or may not be the answer for this.
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Been thanked: 467 times
Re: cooling issue
- hamidm
Re: cooling issue
Thanks for your response. Yes, I have brand new impeller on both engines. Water flow from both exhausts are excellent.
Hamid
- hamidm
Re: cooling issue
Re: cooling issue
The one thing you can try is to drain the degas bottle where there's only a little antifreeze in the bottom (maybe 1/2 or 3/4") and use a wet/dry vac to apply vacuum to where the cap is. If the antifreeze disappears, then add some to bring it back to 1/2-3/4" and use the vac again. Keep doing that until the antifreeze stays at the same level. Then you can refill to the proper level (only up to the add mark!) and put the cap back on and see if that resolved the problem.
- hamidm
Re: cooling issue
- hamidm
Re: cooling issue
I lifted the degas bottle up with the cap removed. started the engine and let it warmup. As soon as the antifreeze started to boil and pour out of the degas bottle, lots of air bubbles started to be released as well. Within 5 minutes all the air was out and the antifreeze level was stabilized. I just added some more antifreeze to bring it to the proper level and I was all done. Ran the engine for 15 minutes the other day and everything seems working fine.
I would like thank everyone for all the help.
Best regards,
Hamid
Users browsing this forum: No registered users and 196 guests
