Vacuflush
Re: Vacuflush
Post by Midnightsun »
Lookin good, no poo poo issues for several summers now. :captain2:
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 211 times
Re: Vacuflush
Post by pepmyster »
Hopefully so! The bills are in the proper direction, couldn't get them all perfectly horizontal , some about 10 degrees off, logically that should not matter, right?
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 149 times
Re: Vacuflush
Post by KyleR »
Orientation shouldn't matter. I've read where some people even align them 90degrees off from each other. Not sure it really has any impact though. ;-)
MV Verity
2002 Carver 396
Re: Vacuflush
It's basically a check valve, it don't give a crap which rotation it is it put in. Pun intended. :-D
pepmyster
8.1 Volvo Penta
Fresh water boating
Re: Vacuflush
Post by pepmyster »
Love the puns in the morning!!!!!!! Makes a smile on my face! I just wanted to check with the wicked knowledge base here. Thanks guys!!!!!!!!
pepmyster
8.1 Volvo Penta
Fresh water boating
Re: Vacuflush
Post by pepmyster »
Alanna Mo Cree wrote:QR_BBPOST I was surprised by how quiet the pump got after changing the bellows. Hopefully this is a once every five years (or more) job.
One tip for putting it back in the boat is to have the mounting screws on the aft side screwed in the boat a little and then slide the pump assembly under them if you can. It's tricky, but I ended up doing that job multiple times. (Long story)
We used your tip for the rear screws and that’s a great call. Also, as you said how it got quieter, very true! Noticeable difference.
