Helm Electronics - Wedge for angling the display 30-45 degrees
- kgarguilo
- Has thanked: 197 times
- Been thanked: 55 times
Re: Helm Electronics - Wedge for angling the display 30-45 degrees
Final post on this topic - after procrastinating with the gelcoat part of this project, I finally finished it. Good grief, this one was hard and I lost interest along the way. About 2 weeks ago, we decided to move back to Lake Lanier GA and in order to save face with my fellow boaters, I needed to finish it up prior to returning to the lake. Here is the result, it looks pretty darn good, [img][/img] [img][/img]
Kevin G.
1999 Carver 406
1999 Carver 406
Nice job, so will you be going into business now...
Honestly it Looks good, it was worth the time considering and researching. Good luck with your move.
- kgarguilo
Not even a little thought, i have been loving retirement (draining my savings accounts) now for just over 3 years
Kevin G.
1999 Carver 406
1999 Carver 406
I like it I like it. Did you build with wood then glass it or just gel over wood?
- kgarguilo
Plywood, cut and nailed and glued, covered with sheets of fiberglass and resin, a lot of sanding, gelcoat by hand at first but decided I needed to spray the final coats which is comprised of the last 2 coats, and about 6 coats by hand. I learned alot by doing this project.
Kevin G.
1999 Carver 406
1999 Carver 406
